Reed Valve Kit - Rock Solid Engines - 80cc, 70cc, 66cc, 60cc, 48cc,
Post by Fabian on Sun Mar 25 2012, 00:20
Just ordered two of these CNC machined reed valve kits from Rock Solid Engines.
Compared to the Arrow Motorized Cycles reed valve kit, they look like a much better designed item; much more compact and have it in spades in the looks factor.
Check it out on their website:
http://shop.rocksolidengines.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=286&category_id=15&option=com_virtuemart&Itemid=1
My installation pictorial is here:
http://motorizedbikeforum.the-talk.net/t209-rock-solid-engines-reed-valve-installation#332
Re: Reed Valve Kit - Rock Solid Engines - 80cc, 70cc, 66cc, 60cc, 48cc,
Post by JaguarCDI on Mon Apr 01 2013, 10:03
It is a very well designed item although its equivalent flow area is equal to a 15mm carb which is fine for a 48cc but a bit limiting for a 69cc. For high performance the Arrow reed valve is probably better although I haven't tried it. The extra compressible area it gives lowers the crankcase compression ratio to lower than low so I don't know how detrimental that is to the high rpm power. But it has a large flow area.
JaguarCDI
Birthday : 1957-10-22
