Grubee SkyHawk Spinning forward HELP !!!
Post by nightwalker on Sat Feb 08 2014, 20:56
Hello Everyone on this awsome form. So Glad that i can talk to people about this. Im kinda clueless. I got a brand new kit and another one from this guy. So i have 2 66/80cc whatever bike motors and set up. I recently got this aluminum Stick to make and dremel and cut for the Tensioner. Put a new drive gear sproket and swapped it cause i have bigger chain. The problem is Now everythings set up pretty good, and with the clutch level pulled in or out now after one ride around the neighborhood (one big circle) It outta nowhere spins going forward and wont spin the motor and now im just clueless to what to do. If i go backwards it snags but forward wont do anything but spin free so im kinda worried. I need it to just roll start again but idk why it wont outta nowhere. Please anyhelp.
Btw im From Augusta,Ga Hick state. lol Nice to meet everyone. I Hope someone knows. Ill attach some pics of both kits.
nightwalker
Birthday : 1988-04-04
Re: Grubee SkyHawk Spinning forward HELP !!!
Post by Fabian on Thu Feb 27 2014, 22:42
You need to tighten up the clutch pressure plate by screwing in the flower nut 3 notches. Remember to reinstall the small screw that stops the flower nut from freely rotating, and do so by applying a small amount of Loctite 222 on the screw threads.
Do not use anything other than Loctite 222.
In my opinion a single speed drive system is a a fairly useless method.
A much better option is to get a SickBikeParts shift kit that allows engine power to go through the rear cassette; allowing you to change gears, just like a car with a manual transmission.
